Assign an IP address to a VLAN to enable routing on the VLAN.
The ability to create an IP interface in a disabled state in one step is available only using CLI.
- Select VLANs.
- On the Basic tab, select the VLAN to configure.
- Select IP.
- On the Primary IP Address tab, select Insert.
- Configure the required parameters.
- Select Insert.
Primary IP Address Field Descriptions
Use the data in the following table to use the Primary IP Address tab.
Name |
Description |
Interface |
Shows the interface to which this entry applies. |
Ip Address |
Specifies the IP address to associate with the VLAN. |
Net Mask |
Specifies the subnet mask associated with the IP address of this entry. The value of the mask is an IP address with all the network bits configured to 1 and all the hosts bits configured to 0. |
Name |
Specifies a name for the interface. |
BcastAddrFormat |
Shows the IP broadcast address format on this interface. |
ReasmMaxSize |
Shows the size of the largest IP datagram which this entity can reassemble from incoming IP fragmented datagrams received on this interface. |
VlanId |
BrouterPort |
Indicates whether this entry corresponds to a brouter port, as oppose to a routable VLAN. |
MacOffset |
Specifies the MAC offset value. Routable VLANS are assigned MAC addresses arbitrarily or by offset. Their MAC addresses are:
If you enter the MAC offset, the lowest 12 bits are 0xA00 plus the offset. If not, they are arbitrary. |
IfType |
Identifies the type of interface. |
VrfId |
Associates the VLAN with a VRF. VRF ID 0 is reserved for the administrative VRF. |
